Hi all,
Decided I'd have a look at my parking sensors on my ML320 to see if there were any obvious loose wires or moisture ingress issues (intermittent fault) which required removing the front bumper of the car.
I got the work instruction AR88.20-P-2000GZ which I followed through (took me AGES) but when I got to final stage of lifting off the bumper it wouldn't come off.
The bumper was lifting up and swinging forwards but it still seemed to be attached to the bodywork at the corner of each light cluster (so basically it was pivoting about that point). It was free and clear everywhere else. I had already removed the obvious bolt from this area (step 2 of the work instruction) yet it still seemed to be clinging on and it was not clear why. If I pulled on the bumper, I could see it trying to pull out the light cluster but I don't think I should need to remove the lights in order to get the bumper off. I was wary of pulling any harder in case I snapped the plastic bumper.
I've attached a couple of photos with the two sticking points highlighted. Anyone done this before and got any ideas - do I just need to prise it off at this point with a screwdriver??
Unfortunately, because I needed to use the car, I had to eventually put the whole thing back together but still want to get in there. MB were going to charge £102 just for the labour of removing the bumper!
Thanks!
Thanks!
