Replace Propeller Shaft Center Bearing
Dec
C180,A.
I really doubt you're going to do this without disconnecting the shaft at either end as the ends don't have UJs they are just the couplings. Just disconnect at the rear and the centre bearing housing and drop it down.
Thanks Dieselman, I see what you mean now, I thought I might be able to "fold" it in the middle but there is no universal joints at the front, will try what you say.
Dec
You have to slacken #11 which is the compression nut on the sliding spline. Normally requires a special Merc spanner but if you drop the shaft slightly a large adjuster can be got in. If it is already slack it shouldn't be. Mark the two halves of the shaft in relation to each other and re-assemble to the same marks to maintain factory balance. Note that even with all the bolts out the rear section has to slide forward about an inch before it will come down cos of the spigot bush #29.
Thanks Druk, sounds like you did this before, good to know it should not be too complicated, I will bear your advice in mind.
Dec
Update;
I just replaced the center bearing and rubber support last week and was surprised at the condition of the rubber. The car is 12 years old with 85,000 miles, so be aware if you hear a “thump” when you increase throttle suddenly while overtaking, it just might be this.
Dec
Update;
Dec
Hi
Had a problem with bushes 14 and 29 on a 280E W123 many years ago.
The tube on the end has moulded rubber with a nylon insert in the middle of it which had split, causing it to rotate off centre. Basically, because it had the split in it, the car vibrated at high speed.
Add
Thread resurrection time...
Does the bearing slide off without too much trouble? I need to do this myself and plan on taking the prop shaft off first to solve the issue.
In my case, a little bit of encouragement with a hammer and chisel, so not as easily as you would like.
Dec
Some UJs have a circlip either inside or outside.
others are pressed in.
