Vectrolosys
I have a 1991 300TE, which is very clean underneath, is good mechanically and needs just careful maintenance to keep it happy.
There is some rust on one of the arches (both on the outer area, which is a surface blemish, and some on the inner arch, which seems a little more severe). There is also some rust around the aerial and under the rear offside side window, that will go to a hole if provoked (I haven't, just covered it in grease and waxoyled behind it)
Now, I had a slight scrape on my gate during the snow and have bought forward my plans to get it repaired. Personally I think it's worth doing but wondered if anyone with W124 experience would like to make comment.
Also, just seeing if anyone else has had similar repairs done and what have they had to pay?
Wheel arch repair and spray (would require a small skim of filler + spray)
Small scrape (Skim and spray)
Rust requiring rear side window removal, possibly cut and weld, then skim and spray
Rust repairs (very small) on another arch, plus spray
Small rust spot treatment
And that's it!!
For a reasonable quality job, what would a typical body repair outfit charge? No accurate figures, just ballpark to be honest.
Thanks all,
James
And that's it!!
Thanks all,
James
