Hi
I've got a 1999/2000 s500 lwb which has seprate controls in the rear for the climate control. Until the weekend they worked as they should blow hot and cold on each side but now they only blow hot air even when turned to the coldest setting(on both sides). The front operates as it should. looking for idea's, do they have a duo valve control seperate for the rear and if so where is it
Cheers
Cheers
