kierankilmartin
- May 15, 2007
- E320 CDI 2002 (W210)
I have a 2002 E320 CDI Estate and the SAT NAV has recently stopped picking up any satellite positioning hence I get this 00SAT in the top right when I look at the map. I have seen some references to this indicating that the cause is usually the antenna. However I am confused as to where the antenna is located. Some discussions talk about it being located under the dashboard others that is in the shark fin on the roof. This is a factory fitted COMMAND if that helps. So before I go looking and attempting to replace can anyone tell me where this antenna is, how I remove it and where I might go to buy a replacement. Thanks KK
