Seat belt slow to retract
Richiebuoy
Northamptonshire
MB CLK 350
My (drivers) seat belt is slow to retract, I usually need to coax it a bit ..... any easy fixes on this ?
(Thanks)
(2008 clk 350 soft top)
Hi Richiebouy,
Had a problem with mine used some see link even has a seat belt on the can !!
http://www.eurocarparts.com/ecp/p/c...ases/maintenance-fluids/?NOR2897322&0&cc5_858
but any quick drying version will do,
Pull the seat belt fully out, spray both sides and allow to retract, extend and retract several times, for good measure spray any plastic trim parts the belt may come in contact with, a good quality silicone spray should have no products which will stain or leave any smell.
HTH
2nd that heaps of silicone spray . just went through all my seat belts . The thing is The Mercedes l have owned would have to be the worst when it comes to sticky belts.
I had slow to retract belts in my last CLK and found 3 in 1 silicone spray worked a treat.
If you have furniture polish in the house that isn't too smelly try that. My Impreza used to have "squeaky belts" and the polish cured that. It also made the car smell like it had been cleaned which was a bonus. Dave.
