500E
Hello all - gave a local garage my car to change the fan belt and the car has returned with the new fan belt totally loose and the tensioner seems to be broken . MB part, 8 rib and confirmed looks same as old with same p/n. Can't drive the car as belt too loose and no way of tightening it.
Does the tensioner break on the m119 or one of those items which is very unlikely to fail? Tried to tighten the bolt below the tensioner itself either way with no success, no tension just floppy, even if I hold tension then tighten, no success. Anything I'm doing wrong? Car is 1992 and was absolutely perfect before it went in (bar cracks in the old belt of course)
Earliest the garage can get out to see the car is Monday which leaves me without the 500e over the weekend.
Cheers
Bill
Cheers
Bill
