Shell V-Power diesel
I got roughly 360-380 miles to that ten gallon of VPower, I've now put ten gallon of 'normal' diesel in so let's see what this returns.....
If you're that worried about pump lubrication, put a Cummins/Fleetguard lubricity filter on. It's used on industrial machinery that burns Jet 1A/Kerosene and other odd oil-based fuels which have almost no lubrication properties.
Sulphur lubricates too, and there's less of it in fuel now (which is a good thing).
I've used it once in the shed and found it worse in fuel, like Will, than normal stuff. About 2-3mpg less. The 220cdi I had before, did rather better on it though, but it had a higher compression ratio than the 320cdi
It was just keen to get away from Birmingham as efficiently as possible :D.
Nothing wrong with Birmingham ;)
I've used V-Power Diesel too a couple of times, didn't notice any difference so went back to the regular Shell Diesel.
When I picked my car up from Birmingham last week I thought I'd put 10 gallon of V Power diesel in just to see if it'd make any difference because I'm very cynical about these things.
So far I seem to be getting more mpg than I would do with 'normal' diesel.
How do you know, it's a new car and your first fill.
I'll try 10 gallon of the normal stuff next and see what the trip computer comes up with.
That's where I went wrong, I put in 17.5 gallons of V-power and now 18 gallons of regular... :doh:
From what I've been told, with the V-Power petrol at least, is that you need to use it regularly in order to see the benefit........
They would say that, wouldn't they ;)
It's a bit like putting 'Repeat' at the end of the instructions on shampoo.
Same 320 V6 CDi as my last W211, so it should be very similar mpg.
I generally put ten gallon in whenever the light comes on, so I know when the car is being thirsty.
So you aren't actually measuring the fuel consumption, just relying on the dashboard guessometer and for one fill only on a new car.
I, on the other hand perform brim to brim calcs every tank.
Hope you don't mind, but I'll stick to my method. :)
I did put 11 gallons into a spare car on Monday evening for a quick trip to Doncaster and back and can say from observation it is definitely more economical than the Mercedes...
Yes, sorry, I don't get too crazy about mpg figures. I can just tell you *roughly* what my IL6 CDi did per gallon and also the V6.
You stick to your spreadsheets, I'll stick to my 10 gallon measurement. :D
