Sidebulbs doesn't turn off on my 190E (W201)
Kapitan_ADNA
Azerbaijan, Baku
Mercedes Benz 190E
recently I bought a 190E and i really dont know what is wrong with it.yesterday i saw that sidebulbs doesn't turn off. I decided to remove fuse but it doesn't work. and after then i disconnected accumulator.
The interesting thing is when i switch to only right side all lights are on. But when i switch to only left side, only left side is on. Do you understand me? My english is not so good...
Your light switch may be broken??? but if your turn the switch as far to the left as it will go the left sidelights will illuminate --this is for parking when the left side of the car is projecting out into the road. Now if you turn the switch one click to the right the right sidelights should illuminate-this is for parking when the right side of the car is projecting out into the road. --one click further all side lights should go out the OFF POSITION ---one click more both sidelights should illuminate---one click more headlights and side lights should illuminate. It would appear that you are missing the right sidelights on and all lights off positions which suggests a broken switch.
Yes, you are right. I wanted to say that in this off position all sidelights are on. I turn it to right, light gets brighter.one click more headlights turns on. I mean everything is ok in this side. ON OFF POSITION SIDELIGHTS CONTINUE ILLUMINATING...
Ok, i'll check light switch first. I'll write results here...
Thanks for help...
After that reply, the next morning, i decided to check. but when i connected accumulator, sidebulbs were off. I mean there wasn't any problem. I checked switch, it is ok. checked wires, it is also ok. and it is very misterious for me what it was. may be there was water from somewhere.
Again thanks for your help...
Glad you got it fixed.:thumb:
