mick benz 320sl
- Oct 9, 2015
- 1998 SL 320
Hi, I hope someone can help with this tricky one.
After having the original MB radio replaced with a new Bluetooth radio. On the odd occasion, On first start up if the SRS light does not light or is lit very dim I have the following malfunctions : Wipers don't work, radio don't work, indicators only flash for a left turn even when you try a right turn. This only happens 50% of the time on first start up. If the SRS light lights as it should on start up I have none of the problems at all for the journey .It only happens on first start up and only started happening since the radio change. I have tried disconnecting the new radio but still have the problem on occasion.
