OP
OP
Deleted upon users own request member 138506
Guest
I'm not disagreeing with you but I think I'll give Acid a call and ask why he took out the ECU. I'm just curious and trying to learn.If you have the M157 5.5 biturbo, the map is done through the OBD port.
It says here...
How do I get a stock file for my car to go to the dealer with? Generally you would read the stock file, send it to Eurocharged, we will modify it and send it back. However, the 63 ECU cannot be read via OBDII so the device will only ID the car. Once you have this ID file, you send it to us. We will then match your stock software based on the ID file, attach it to an email and send it on the way to you. From that point forward, you load all tunes via the same method.To sum it up, the device will arrive blank. We will send all files via email for you to load / manage.
So based on the above I would assume that any modification would be to a generic map for the car
