- Jul 12, 2011
- Location
- Near Salisbury
- MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
I have been slowly fixing a few little niggles on my 2003 C320 saloon and I am now enjoying the car very much.:bannana:
Two things remain that are still unresolved and I am not sure if they are related or not.
When driving slowly in traffic I can hear a light metallic rattle that seems to come from the rear. I have looked at the rear suspension and could find no obvious source.
It seemes to go away with a light application of the brakes but this could just be the fact that the car is moving more slowly and there is not enough energy / momentum to trigger the noise.
The other issue is that my parking brake is still not releasing fully when I pull the release handle. I need to get into the footbrake mechanism to properly lubricate it as spraying silicon into the area under the dashboard seems to help for a day or so.
Could a partly sticking parking brake cause such noises or possibly the brake pads ratttling in the caliper? the retaining spring seems to be correctly fitted. I am having new pads fitted soon so that may rule out one cause!
The other thing that sprang to mind was the rear drop links.............
Many thanks.
Many thanks.
