Slipping Gear Repair
jenz
UK
Mercedes 300TE 24v
Hello,
Has anyone heard or used a product called Lucasoil Transmission Fix?
See url: http://www.lucasoil.com/testimonials/1991,1.html
I am tempted to use it for the slipping reverse that I am getting.
Please, please, please let me know if this is real or a hoax.
Regards
Jenz
Personally I wouldn't put any additive into an auto-box. All the seals and clutch plates are designed for using a certain ATF and no other.
This product will almost certainly be a seal sweller designed to increase pressure within the box. When the box then fails, and it will, every seal and clutch plate will need renewing.
If it sounds too good to be true, it usually is.
try changing the trasmission oil
