Brian J.
- Oct 18, 2011
- Location
- Guildford
- SLK 230, 2002, Chalcedony Blue Metallic, AMG wheels and body kit.
I have a couple of oil leaks from the differential on my Slk 230. One is from the front pinion seal and the other from the gasket at the rear of the diff.
I understand that the pinion seal has a squashable ring which ensures that tolerances are within bounds. Does anyone know how to get this setting correctly as I have been told that if incorrecly set, it can put offset loads on the pinion bearing making it whine, which is what I have at the moment.
Any information on this suject would be very welcome.
