SLK PSE Vacuum Pipes
Tim Soles
SLK 230, BMW 530D
My 2000 SLK 230 has suffered from the usual problem of damp affecting the PSE unit in the boot.
The interior light had a mind of its own, the central locking was eratic and often locked and unlocked whilst driving, and I had occasional false alarms.
Having taken the unit to bits, the corrosion was very slight with just some damp in the white electrical connector causing the pins to slightly corrode. I've carefully cleaned it up and all seems well at the moment.
However, I would like to turn the unit upside down (as on later models) to stop more water running down the wires and into the unit. The wires are long enough but the 3 yellow vacuum pipes need extending. Can anyone tell me if they have done this and what pipes they used for the extension? Vacuum pipe is advertised on eBay but I am not sure about sizes and how to connect to the existing pipes.
Cheers, Tim
I am sticking my neck out here, but I used extensions by using pipe from a indoor fish shop that is used for aerating the tanks to repair damaged comfort seat pipes.
When warm, this pipe only need to slide over the join 20mm.
By the way before you put you PCB back, pop into Maplins and get a can of PCB lacquer and spray the board twice
I have done this too. Posted a how to here;
http://www.benzworld.org/forums/r170-slk-class/1270676-pse-removal-refit-check.html
I used plastic pipe that slid over but only as I had it lying around. Next time I would just use small bore rubber auto vac hose. Fish tank pipe is ok but in longer lengths may suck in.
Bazzle
Thank you Bazzle for pointing that out, fish tank pipe is not as hard as the MB version but I doubt if it would suck in, its quite thick.
Every hand spray cleaner bottles for kitchens and bathrooms has several sizes of pipe and one way valves, these valves are perfect for testing seats etc from an external compressor
Thanks for the link Bazzle - excellent Post.
I thought I had fixed my problem but when I took the car out today the interior light came on everytime I went over the slightest bump, and the central locking was also trying to unlock from time to time. Is this definitely the PSE?
The board looked clean and the only damage I could find was in the white connector. It's difficult to clean the pins in the connector, but I will try again next weekend. Presumably, if the connector pins are badly corroded there will be no choice but to replace the PSE?
I will also give the board a gentle rub - is WD40 OK for this? I will get some PCB laquer for future protection and some vac hose so I can turn the unit upside down.
Tim
Any non drying switch cleaner (maplins) will take away any white corrosion from the connectors.
You can get dry soldered joints on these boards, looking through a good magnifying glass you can see if there are any where there are dark rings around any of the joints. Its best to blanket solder the whole board
If you cannot do this I could do it for you FOC.
I ended up replacing the PSE unit this weekend, largely because of the continued alarm problems which was causing upset with my neighbours.
Incidently, my local MB Stealer said that MB had none in stock in the UK and they were on back order with an unknown delivery date. However, he was able to tell me of another local dealer who had one in stock - it only cost £373.65!!!!!!
The good news is that the false alarms and door locking/unlocking problems seem to be resolved. The bad news is that the interior light is now staying on! Having said that - if I start to open the window the light goes off!
I am guessing the current drain for the window is enough to kick-start the interior light dimmer.
I am open to any suggestions, but I am wondering whether it is a problem with one of the contacts that plugs into the PSE. Would some kind person who has access to a wiring diagram be able to tell me the colour of the wires that plug into the PSE that control the lighting circuit? That will help me to identify which pins might be causing the problem (if that is the problem).
My car is a 2000 facelift model 170.449. The PSE unit is part number 1708000848 - it has two big connectors at one end (one black, one white, and two smaller connectors at the other end.
Cheers
Tim
VIDEOS included - Forex trading"Something Fantastic" happens every day at the same time, to the same stock index... forex currency that will make you rich! forex street Karl Dittmann (Germany) - 30 years of trading experience forex market hours If you learn the one hidden secret which is repeated daily for years, you will make an incredible profit! mini forex trading One single stock index trade within 15 minutes of the market pening is all you need! forex trades What if you knew a trading secret so simple, yet so powerful, that anyone could use to profit from the Stock market even without experience. All You need is to trade Single Stock Index - 15 minutes at the opening. 30-50 ticks daily can be yours! managed forex trading This is Guaranteed! forex euro There is no way to lose money! forex trading tutorials Forget Indicators and stock trading guides! forex trading platforms There is "something" which happens every day at the same time with the same Stock Index...! forex trading platform This is when you can make real money! forex directory It is absolutely possible to have 9 or even 10 winning trades out of 10... All you need is to know the secret and exact trading algorithm. The secret can be used for some other major stocks too! global forex This Secret Will Completely Change Your Life! forex tutorials The System is 100% mechanical and doesn't need any tech indicators or other tech materials... forex seminars it can be used by anyone... even beginners. Newbies will like the simplicity while experts will like the ease of use and amazing stock index trading idea .... forex management It is a complete plug and play system can be used by any people even without any experience of Stock indices trading! forex demo All You need is the idea and the exact plug-n-play trading algorithm. forex trading forum Finally, these unbelievable trading secret are available to the public for the first time ever. forex made easy This method have the potential to completely change your life. forex tips 100% Mechanical system, which have been hidden for years, known to only a group of Wealthy Trading Elite! forex information Join us know... trade forex I guarantee once you read and apply for our method - you will never look back, and never want to use any other trading Stock market system! forex charting wow gold warcraft gold
PSE Vacuum Pump
Cheers
Tim
Hi Tim,
I have a 2000 SLK230 with the same problem. I cleaned up the water damaged PSE and locks and alarm work, but not the interior lighting. The dome light dimmer does not work. The dome light and trunk light stay on even with its switch in the center position with doors and trunk (boot) closed. The dome/trunk lights will go out after 5 minutes. It appears the PSE is not getting the door/truck closed signal. I suspect the white 18pin PSE connector is the problem and not making a good connection. I will try cleaning it again. It could also be one of the door or trunk switches. If you did, what did you do to fix your problem?
Rick
thanks guys. very helpful
