In changing over a set of wheels on my W126 in order to replace worn tyres ( I have two sets of MB 15 hole alloys ) I have had the well known problem of wheel bolts that hadn't been out for a while snapping - a total of four bolts out of the twenty , two on each offside wheel !
When I first discovered them to be tight , and being aware of the possibility of them snapping , I spent a while trying to ease them out gently , tried to spray penetrating oil in , with little hope of it reaching the threads , and left them for a couple of weeks in the forlorn hope that they might free up . There were quite a few stubborn bolts , the wheels not having been off in about a year , but all apart from these four came out .
These are the long bolts with the thin extended section which have been known to break in the past and I know there are modified bolts available to replace them .
Because of the way the snapped bolts are recessed into the wheel , there seems no option other than to drill them out - only they seem to be made of such hard metal that I have spent most of yesterday drilling away and made little headway , whilst blunting countless drill bits .
These bolts are so tight that I doubt an 'easy out' would help , Applying heat or welding something onto the stub of the bolt would be impossible without damaging the wheel .
I was hoping to drill the bolt out until the tapered seat came away , allowing me to remove the wheel , then with application of heat to the hub , remove the remains of the bolt , or just get a hub from another car since I plan to replace the discs anyway .
Has anyone else been through this , and how did you get them out ?
