The normal fault for the SRS light coming on is as stated above the passenger seat occupancy sensor, but in the O/P's case the code kicked up as "passenger side front seat belt", this to mean is pointing to a seat belt pre-tensioner fault NOT a seat switch/wiring fault. Depending where the pre-tensioners are fitted (either the seat belt reel itself or the seat belt stalk), I think you need to replace it or check the wiring integrity to it.
O/P I have just re-read the title of the thread and you state "passenger seat" and your text in the thread it say "Passenger side seat belt", which is it? Or did the title box to the thread run out of letters.
