hi all need some help here or a miracle , i have real problems with this car , first got it about 4 months ago , drives like a dream until i took it to have a full service , brakes , filters , transmission fluid , filter and gasket , etc , after 5 mins of leaving the garage to the car started make a loud clunking noise from under the car , this noise is only when accelerating no other time , trip back to the garage he said its the u joint on the prop shaft , well that changed now ( ujoint and rear prop shaft ) , just the same , then it was gearbox mounting , still the same , next axle bushes worn , net still the same , next the GEARBOX after someone else looking at this and saying the same , ordered a secondhand gearbox with warranty , thats been changed , guess what the same noise is there but worse , well im fuming and stumped , ive spent around £1500 on this car maybe more , so hes saying hes going to swap the transfer cases over and see if thats it , but if the first gearbox was the problem why swap it for one thats sounds worse , im thinking its something that either connects to the gearbox or some thing else underneath , i cant see how 2 gearboxes have the exact same problem ,
