OK we will ignore the reasons then.
Yes, in general it can be done.
Mine was lowered as part of a coilover suspension upgrade.
You've not stated what year your model is so there may be a chance that the option is greyed out for a reason and that in your particular case it can't be done or requires a factory only edition of STAR do carry out.
If local dealer says no then that's probably the case unless a specialist Indy such as Olli says otherwise?
I'm presuming you have seat(s) adjusted as low as possible already? Would it be possible to lower the seat(s) further by modifying the runners/frame?
If a current or very young model, then STAR 'mods' can only be done using a file download/authorised from Germany.
Any Car with Airmatic or SLS can be lowered to a degree with STAR.
I can understand people with sporty mercs wanting a better handling stance etc but why buy a 4x4 then start trying to make it something it isn't?
Lowering a car will upset it's geometry and massively increase tyre wear if in turn the lowing can not be compensated by laser alignment,
There are modules out there that lower at a pre programmed time. Lads on the us forums use them on their w220s to lower when the car is locked.
I'd imagine you could have similar results from the car lowering, perhaps when you remove the key?
Alps, how come only an inch on star? If airmatic cars are left for prolonged periods, they drop by a good 4 or so inches at least. Is it that the shocks only operate within a certain range? So need to be at a certain height for driving?
Wrong! W164 ML with Airmatic cannot be lowered by STAR.... believe it i've tried....
mmm i appologise then.. so how much can you lower with Star as i'll get olli to give it another go before the links...
