steering rack leaking on top
Olivier
Edinburgh
E300 TD
Hello,
I need to replace the Oring at the shaft in the steering colomn as its leaking.
From whar I can see, the top piece is held by only 2 allen type bolts and the piping for the fluids.
Can this be lifted without any bother?
What should I expect if I pull it out? Any spring/ things that goes wrong etc.... or its just "plug and play" type?
I have no internet at the moment then I might take awhle to reply.
Thank you.
Olivier
