My new to me CLK 270 CDI W209 with 65k miles is making a strange clicking noise from the gear box area when its under load. The clicking speeds up with the speed of the car, at first I was thinking something touching the prop shaft but its been up on the ramps and nothing to be seen. The noise seems a little less obvious when the car is cold and if you go around a left hand bend it stops! I have had all 4 wheels checked to see if there is obvious but again nothing.
Its defo coming from the gear box area because if I open the ash tray or centre arm rest the noise becomes a little louder.
The specialist I took it to was flummoxed, there are no faults with the way it drives and the noise can not be hear when the car drives pass as I got Mrs C to drive past me. Just revving the car in neutral does not make the click.
