Hi all,
The sunroof on my w202 1999 is acting up. It opens fully but when I i press slide close it closes to the last one inch. However if I press the Tilt UP button it closes fully and then raises by just a few millimetres. Even if I close it using the tilt/up button and then press the slide close button it opens an inch. weird.
It was working just fine a few days ago and then suddenly now it is not. I have tried normalizing again by taking the fuse out and then re-syncing but still the same problem.
Some of the forums mention a hall effect sensor may be the culprit. Any ideas on how to reset that?
Any help will be appreciated.
Usman
Usman
