Birdman
COUPE FREAK said:can't you see the pic,,
it's a "HARLEY DAVIDSON"
Oh I can see that. It's the model I was asking about.
I ride motorbikes too, remember?
Here's one of mine I made earlier!! It's a....(you tell me!)
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
Birdman said:Oh I can see that. It's the model I was asking about.
Here's one of mine I made earlier!! It's a....(you tell me!)![]()
I'm with Birdman here, have to totally disagree that a new engine should be subjected to heavy loading to assist running-in. Fast, yes (within reason of course) but under light load always. Should never be allowed to 'labour'. Opinion only of course, but no-one will change my mind.Dieselman said:The same really applies to car engines.
Rather than thrashing an engine I would go for revving the engine at full load (steep hill, heavy load) several times for the first twenty miles or so. This will definately reduce bore glaze and will ensure the piston rings seat well into the cylinders.
TKB13 said:I'm with Birdman here, have to totally disagree that a new engine should be subjected to heavy loading to assist running-in. Fast, yes (within reason of course) but under light load always. Should never be allowed to 'labour'. Opinion only of course, but no-one will change my mind.
Dieselman said:Consider this.
When an engine is revved higher it creates heat which is bad for new components.
Also what to you think creates the good seal between the rings and the bores? Cylinder pressure, which will be greatest when the engine is working harder, not faster.
Another point to consider is that all new engines pass oil by the rings until they seat properly. The oil is what causes glazing. Once cylinders are glazed the rings can never seat unless the liners are glaze busted.
It has been known for a long time that a gentle same speed cruise is the worst way to run an engine in. The engine speed should be constantly varied and should not sit at a constant rpm.
http://www.mototuneusa.com/break_in_secrets.htm
tamrsoft said:Q - I am baffled by the quantity of engine oil my BMW 520 (51 reg, 104,000 miles) consumes, right from its early days. I seem to put in a litre of oil every week. Is this normal? There does not seem to be any leakag.? Smit Bharadwaj, Ashford
Birdman said:Couldn't help noticing the link is to a performance biking site![]()
I read the linked page with interest because it's backed up empirically.
There is a difference between bikes and cars in that modern high-revving bikes (10 - 14 000 rpm) have factory coatings on the cylinder bores and pistons, and these coatings must chemically react with each other during the run-in period for the pistons to bed-in correctly. High temperature/pressure combinations over the first 200 miles or so are needed to do this. So it is not just a "wear" issue but also a chemical reaction laying down a new micro-coating on piston and bore. If the rider doesn't create the neccessary conditions for high temperatures/pressures during the early run-in miles this change will never happen and the engine will under-perform and eat oil over the whole of its remaining life. Which, it may surprise people to know, can run to over 100 000 miles before repair even on these screamers!
So high-performance bikers needs to be a bit more demanding on their engine than car drivers during the run-in period (HD and other cruiser owners don't need to read this, it will only serve to alarm!).
Birdman said:You think it's not about "wear". Read this!
http://www.thedieselstop.com/contents/getitems.php3?Breaking in a Diesel Engine
I think there may perhaps be a difference of opinion here!![]()
