Tensioner shock absorber
Paul64
South of France
1995 W124 E300 Diesel estate (250k miles), 2008 CL63 AMG, 1969 Triumph 2.5PI, 1975 Triumph TR6
Hi all,
I have a little rattle in the mornings from my '95 300D and traced it pretty quickly to the top bearing-bush in the shock absorber of the belt tensioner.
If you just apply a little pressure to it with a finger, the noise vanishes. It's generally quieter when the engine's warm too.
I spoke to the local independent MB tech and he said these items don't generally last more than a year or so before becoming noisy again - is there an upgrade for these plastic bushes perhaps to extend the life of the part??
I have a receipt from 18 months ago showing the part was changed then so perhaps it's true? A weak bit of Engineering from MB in the early '90's, surely not???!!!
Paul
Undo the damper, push the centre rubber out of the eye, wrap material loom tape inside the metal eye, push the rubber back in.
Thanks Nick, Dieselman - washers on the way.
Can't understand why this wasn't fixed during production??
Paul
Don't know what he means,I had to replace it on my old saloon and 18k later after 3years was still ok.Maybe is diesel engines only
