The EV fact thread
Charged the battery today on an 11kW AC charger. Total electricity supplied is 16.1kWh.
The battery percentage went from 51% to 68%. The difference, 17% is equal to 14.3kWh, given the 84kWh battery.
I trust the first figure (16.1kWh), but the percentage figure is probably not accurate. Having said that, on the face of it, it seems that the loss is around 11%. Taking into account the potential inaccuracy of the percentage figure, I'd say it probably somewhere around the 10% mark, give-or-take.
Some of this might be intentional - warming up the battery - some might be simply due to the electrical resistance of the charging cable and other consumers along the route.
The slower the charge the higher the loss percentage is. That's due to the fixed overhead in running the 12V systems in the car that monitor & control the charging - running these for longer in relation to the kWh added makes the loss percentage worse.
With AC charging there are some additional losses in the car's internal charger, converting this to DC. If you supply the car with DC these losses occur in the charging station instead and aren't (AFAIK) visible ... I assume they get factored into the price you pay for the charge.
I think resistive losses in cables & connectors will be negligible - they'd get hot otherwise!
🙄🤪🤯:doh::dk:;):)👍
..I think resistive losses in cables & connectors will be negligible - they'd get hot otherwise!
They might be getting hot - I don't know - the insulation is very think, and so I guess that they could get quite warm internally without heating the external surface of the cable (but this does not mean that they actually do).
They’ll be designed for purpose for the continued current draw - that’s why the cables are quite thick. Sure they might be fractionally warm but no way should they get hot in use.
As BTB mentions the car batteries themselves charge on DC. The onboard charged (AC-DC) is where most of the losses will occur (ever felt a conventional ‘charger’ in use? :)
I think the cables are quite hefty so I'd be surprised if there was significant resistance there, but any losses would be proportional to the charge rate of course. When looking at (slow) home charging ADAC said under 1% loss in the charge cable (compared to up to 4% in the mains wiring to the charge point).
Depends on the length of cabling to the charge point, and the thickness of course.
That's from America, but it's encouraging to see that the second-hand market is all geared up to deal with EV battery degradation, taking away the guesswork and risk. Hope to see this coming to the UK soon.
I would guess that's specific to Tesla though (and maybe not all models/years?), rather than being generic.
Well, it's because they've been around the longest, I guess. How many other EVs do you find with 200,000 miles on the clock? Hopefully, in time, traders will develop similar expertise with other marques aa well.
It will depend on what individual models log though (e.g. percentage of fast charging used), and what they can expose via diagnostic etc. interfaces.
If companies will provide decent battery warranties on used cars based on that type of data then it would be great. If it was me though I'd want info. on how often it had been charged to 100% (or run down to 0) as that can reduce battery life. Also the total number of charge cycles.
But was you bovvered?
You added 17% of capacity without any fuss and at very low cost
So... I am in Switzerland.
Same route as last year, traveling to Calais, then through Reims and Dijon to Switzerland.
I was expecting an easy journey like I had last year, and was also looking forward to try the new IONIQ 5 which has a larger battery, faster charging, improved suspension, and even better driver aids. But it didn't turn out quite as expected.
The first alarm bell rang the night before our planned departure, when a text message from Le Shuttle warned us that we must ensure that we are on time because they expect to be 'very busy'. Which I thought was odd, because we had the Flexy Plus tickets.
On arrival, we had to drive to the main terminal for the pet passport control (Her Ladyship the dog may be tiny in size but she commands our every move....), and the place was packed. I mean packed. I've never seen the carpark so full, to the extent that it was difficult to find a parking place.
The train journey itself went fine (yes, the Flexy Plus ticket does work....), and I thought this was the end of it.
Not so. We stopped on the first main Services on the Autoroute, some 125km after leaving Calais. There were 5 Ionity 300kW superchargers there, and last year we were the only EV charging.
But this time, all 5 superchargers were busy, with 3 cars queing. I left home with 100% charge, and so the car didn't really need charging, I was just following the ABRP 'top-up' plan. We were supposed to charge there for 6 minutes.
As we already stopped, we decided to take a break anyway, and I plugged the car into a cheaper 50kW charger which was free. I did notice thar the wait for the supercharger would have been 10-15 minutes. We left, then tried another Setvice some 100km further, and it was the same - all Superchargers busy, 3 cars queing.
This time we just waited, again it was around 15 minutes before we got to the charger.
After moving further away from Calais, we had no more issues with finding a free supercharger at Services along the Autoroutes.
A few things struck me. First and foremost, the idea of very very short 5-10 minutes top-ups does not really work if you have to wait 10-15 minutes every time. It makes more sense to have less stops, and charge a bit longer, when there's a 10-15 minutes wait. It's all down to how I program ABRP, obviously, i.e. I can set it to plan the route with less frequent but longer stops, but the key here is that ABRP cannot know how many cars are queing and therefore cannot know how long they wait will be.
The other is that the charging stations were totally unprepared for overcapacity. There were no spaces or road marking for queing. And so, on arrival, the cars just drove up to the charging station, then stopped randomly wherever they could. We got out of the car and started chatting to the other drivers, in what was an instant and short-lived community :D, and agreed between ourselves who's next. While we enjoyed the chat, a marked lane allowing cars to line up at the entrance to the charging area would have been the more sensible approach. Maybe it's just the French, maybe they don't know how to form an orderly queue, in spite of donating the word to us? 🤔
Next, I realised that while the onboard satnav showed dozens of fast chargers (100-200kW) within under 10 kilometres from where we where, it still made no sense to leave the Autoroute - you'll need to exit via the toll booths, drive to the fast charger (typically in a local Carrefour car park, or outside a car dealership or a garage, etc), then get back on the Autoroute via the toll booths again, so really no time saved.
Then, I'm told that Saturday 19th was the beginning of the school holiday in the UK and many parts of Europe? Having no school-age kids, we have no idea. But I did notice that driving away from Calais, about a third of the cars on the Autoroute had UK plates (and most had no UK marks on the plate or on the back of the car - how do they get away with it?). As we moved further away, there were fewer UK cars, but still, around half the cars on the Autoroute had non-French plates. The majority of cars had either bikes carried externally or roof boxes or both. Some had trailers, and obviously, there were quite a few motorhones and caravans. In short, it was obviously the height of the tourist season :D
At the two busy charging stations, there were no French cars at all - the cars were from the UK, Belgium, the Netherlands, Denmark, and a few other European countries.
This raised two questions: the first is why do half of Europe's countries start their school summer holiday on the same Saturday? The second question is, what were all these European cars doing on the Autoroute going from Calais? I.e., they clearly didn't arrive on the Le Shuttle like the UK cars did. What route goes from North Europe to the south of France via Calais?
My other observation is that the locals largely shun the expensive Autoroutes (we paid €55 for the first day of the journey). This also explains why there are few cars on the Autoroute and no cars at all at the charging stations when it's not the tourist season....
The lesson learnt is that as a couple without school-age kids, we should check the European school holiday calendar before travelling to the Continent....
The car, BTW, proved to be brilliant - the New IONIQ 5 is better than its predecessor in every way. The efficiency is better, the range is much much better, the ride is improved, and the driver aids tech has also matured.
I was waiting for the punchline of this joke but it didn’t arrive
Can’t believe that you drove on the second busiest traffic day in Europe without realising where you were.
I hope you weren’t driving yesterday when there would have been hundreds of miles of motorway queues just on on one motorway in France.
And seriously, you’re surprised that people top up their fuel off the motorway network ? Really? Did you used to fill your petrol tank with motorway fuel in the UK? Where it’s at least 20% more expensive than a normal forecourt? (Call it £1-70 a litre, if you will.)
Saw an ad today for Motorpoint.
Dacia Spring 2025 car with 77 miles on the clock.
£9999!
Seems like a bargain for a shopping car, 0-60 in 20 seconds 😂
It’s only about a grand more than that useless Citroen Ami.
If I didn’t have my van for tip and dog duties I would be looking seriously at one of these, piss easy to park in the village and could run on peanuts.
Had to fact check…muttering “Motorpoint” ….
Mon dieu. Over 100 Dacia Spring up for sale below £12k, many from Renault main dealers. And probably “doing deals” at closer to £10k.
Call it 30% off list price.
44bhp with a range of maybe 120-140 miles, dependent on spec. Fine for a runabout, or Evri courier , but not for towing a caravan 300 miles at 70 mph without a stop
Crazy bargains, all being off-loaded before the registration plate change in September.
(And that’ll be the tip of the iceberg, with many not listed but sitting in Renault UK’s central stock of unsold cars)
Interesting in itself but indicative on the price pressure that’ll be put on second hand EVs . VW e-Golf and e-Up! We’re looking at you. FIAT 500e: look away in terrified shame. (They’re twice the price albeit way cooler)
Totally bargain for someone who's not a badge snob. Fancies an EV. And never ventures, out of Town or City. Perfect!
Pardon? I am in Switzerland now, no longer in France.... Nothing is 'low cost' here... especially not electricity from public chargers. I might cross back to France for my next top-up :D
Heavy discounts on mainstream metal has forever been the case. I used to regularly visit car supermarkets in the nineties and early noughties with long lines of delivery mileage registered cars like this, with huge discounts.
Certainly used to be very common back then (I bought a 'pre-reg' Honda in 2003), but it's not something I've been aware of it in recent years? :dk:
Specifically with EVs though it could help manufacturers avoid potential fines from the ZEV Mandate scheme if they're at risk of missing the 2025 target.
The new and used car markets have been more than a little anomalous in recent years.
