ROBB
A couple of weeks ago i opened the door to get in and there was approx 1" of water in the footwell
After a little investigation i determined that the right hand side runoff (inside engine bay) was blocked, and duly proceeded to clear it with a long bendy pokey thing: which seemed to help.
I have already replaced the small drip moulding on the LHS bottom corner of windscreen/A Pillar
As it rained last night there is more water there this morning , so i took out the wheel arch liner to check the water drain mouldings from underneath - cleared a little crud there and the watering can test seemed to pass: the drain water was going out all of the right places.
As it rained again earlier - i went out to check and the water is collecting again: Where can it be getting in????????
I have a tube of Dow Corning and a brush with the intention of sealing the plastic covering along the bottom of the windscreen just in case, but am grasping at straws now......
Any Ideas???
thanks
rob
Any Ideas???
thanks
rob
