dad4geer
I am still confused as how this whole thing works..
What is the purpose of "AUTO", button 12 in the attached picture? Do we use it when we have to activate climate control so I want some other temp and missus wants something else? most of the time it's only me driving so in that case I should not be using AUTO? Am I right? I normally keep AUTO deactiavted as what I noticed that if it is activated I don't get any Air from the centre vents only from side vents.
If I set a temperature, same temperature both sides, is it necessary to Activate Auto? today as it was a bit cold in the morning, I set the dial to 25C and started getting warm nice air from all vents..but then I noticed the A/C light switched on button 4. I was still getting warm air...Why the A/C light came up? my understanding is that it is for cool air (to be used during summer?) I had to press the A/C button to switch it off and even after that I was getting the same warm air.. not sure why it came up and what is the function of that A/C button when I have set a warmer temp compared to outside.
How would you set temperature during winter days? just set the dial to 25-26 and then set Air distribution using button 8, keeping AUTO off and A/C off?
The Zone, button 3, is that used when you want to set different temp for driver and passenger?
Thanks for help!
Thanks for help!
