flango
Hardcore MB Enthusiast
Excellent post. I will be making similar choices when my 202 dies. However I will buy second hand.
I got two suprises reading this:
1) The negative about the Subaru diesel. They've had 10 years to develop this boxer diesel! Maybe the dealer is telling porkies - he just wants to sell what he's got?
2) Thought the Audi Quattro system was full-time 4WD with 3 differentials? Much more expensive than Haldex systems, and Quattro would be better for towing (e.g. up a steep wet pier with 1 ton of boat).
1. I've heard this from a few sources now cylinder heads appear to be a problem and some major failures are occuring at around the 24k mark although covered by warranty and I'm sure they will fix the problem it's still not good so I'm steering clear.
2. Both Audi and Kuga have full time four wheel drive both via the Haldex system below is the quote from Audi website
"Audi uses a Haldex® clutch to transmit power on its cars with transverse engines and quattro® permanent all-wheel drive. It has been specially adapted to this configuration and distributes the drive force variably between the front and rear wheels, preventing the build-up of stresses in the power train when cornering (like the Torsen® differential). The Haldex® clutch has advantages for all-wheel drive in conjunction with a transverse-mounted engines. A lot of different information is needed to distribute power to the wheels – for example, the engine speed, torque, wheel speed and anti-lock braking system (ABS) function.
*) Trademark of Haldex AB, Landskrona, Sweden "
