thanks for all the info.
I don't know if you all have read my previous related posts titled 'engine knocks at 1250 rpm'. For the full story you may have to research back over the past 10 days.
This is still an on going saga, cut a long story short.
engine suffered bad starting one morning so I re[placed all glow plugs and all was well. then I noticed a knocking at idle and up to 1250 rpm, rev the engine higher and knocking disappears, let the revs fall and knocking returns at 1250rpm and back at idle.
Replaced all fuel lines, filters and had injectors refurbished TWICE (same specialist, im still convince that the injectors are faulty), checked all dampers, aux tensioner, new engine oil with hyd valve treatment.
Engine still knocks within that particular rev range (idle and 1250 rpm) otherwise it runs smooth as silk.
This knock suddenly developed. my dad thinks it coincided with the replacement of the glow plugs. glow plugs were the correct one for the engine same part number.
Car has done 47000 genuine miles with FMBSH.
The car is going into mercedes on Tuesday for a diagnostic and hopefully they will pin point the problem.
like I said please read back old posts for full story as its a bit long winded to explain it again.
