mykulmerc
A friend has a "51" plate Mondeo 2.0 TDCi LX (115). Her tame mechanic was talking about timing belt replacement - until then I was sure they had chains not belts (engines should be held together with bits of metal, not elastic bands)
I did just check this to make sure I wasn't going loopy, but in the process have references to replacing the chain as you would a belt.
Can anybody confirm/deny this. I always thought a chain was as good as permanent, as is the case on my W202.
