The transmission shift system automatically adapts to the individual driving style of the driver by adjusting its shift points.
This shift point adjustment is a continuous process which reflects the current operating situation and driving conditions and the driver's requirements.
If operating circumstances change, the automatic transmission reacts by adjusting the gear shift programme.
Accelerator pedal position
Light throttle = early upshifts
More throttle = later upshifts
Kickdown - depress the accelerator beyond the pressure point = maximum acceleration, shift down to the lowest possible gear.
Release the accelerator pedal as soon as the desired speed has been reached - the transmission will shift back up.
Programme selection button
You can swap between the W and S programmes by pressing W/S button.
The programme currently selected is indicated in the instrument cluster display.
S Standard
This position is used in all normal driving conditions.
W Winter
The car pulls away in second gear. When reversing, the car pulls away more sensitively due to a "longer" ratio.
Gear shifts, both up and down, are made at lower road and engine speeds than when the programme selector switch is in the S driving programme, even when the throttle is open.
Gear shifts with the accelerator pedal in the kickdown position are carried out as in the S programme.
