Uneven rear inner tyre wear,which reasons??
Mo-benz
WEST YORKSHIRE
C63AMG//PP- MSL/WEISTEC 758BHP-SUPERCHARGED MONSTER
Hi all just need to of anybody who has experienced this , I used to run 255/30/19 tyres on rear axle but moved a notch up to 265/30/19 , not a great difference as the tyre still looks like it's the same size but Iv noticed on the rear tyres are starting to go on the inner sides of both, I don't know if it is the width that Iv added or camber needs to be done to accept the new geometry of the axle. Any ideas anyone please do let know..
It's normal for a C63 to wear the inside edge of the tyres.
If you check the fronts you will probably find they are the same too.
The wear is smooth, you have to look closely to tell but it is there , it shows significant wear.
I kind of knew about the fronts , the fronts have not even shown any wear and I regularly depending how much uneven roads I go on I have the tracking on fronts checked most times but on the back it is the first time I noticed this unevenness. Could cambering the rear be done to near -0- camber balance?
I forget to mention the tyres have not even managed 1200 miles I'd say. I drive car how it's meant to be driven but not lunatically, thanks
Problem is the rear cambers not adjustable on your car.... You could off-set the wear a little by moving the adjustable toe more positive
