Hi guys, some advice required please.
Recently had a 'B' service on our 208 CLk Cab. and they picked up that the front tyres were wearing unevenly - almost bald on the outer shoulders. The recommedation was to get the geometry checked when the tyres were replaced. With the state of the roads, and the fact that my wife had hit a fairly large pot-hole while in Ireland recently causing the rear head rests to shoot up, I didn't think this was un-reasonable! Did a few more miles while I worried about this and then decided to replace the front tyres and get the geometry checked/fixed at the stealers.
Well, the car was booked in today at Canary Wharf - quoted up to £260 to check and adjust the geometry and £200 for the tyres - all plus the dreaded VAT!
My wife picked up the car this evening and they told her that everything was within Mercedes specifications and no adjustments were made. The charge for the tyres was as expected but they only (only!) charged £105 for the geometry check. They suggested that the uneven tyre wear was caused by incorrect tyre pressures.
Now I check the tyre pressures every time I wash the car (not as often as I should but fairly regularly!) and they have never needed much adjustment, up or down. Does this sound reasonable, bearing in mind most of the wear was on the outside shoulder of the tyres and worse on the passenger side?
I have attached a jpg of the geometry print out. Could someone more knowledgeable about these things give it the once over and let me know if there is a problem?
Many thanks
DaveA
Many thanks
DaveA
