mattc
Picture the scene. Glorious day on Wednesday so head to work in the coupe and, at lunchtime, take a colleague for a very short (10 minute) run down the A5 and back before stopping off at a shop for a sandwich. Come back to car to find it having a small wee in the road which appeared to eminate from the slightly left of the engine centreline (roughly where the 2 turbos are).
I topped up with maybe 300ml and drove approxiamtely 1 miles back to work where I expected to see more water being expelled. Nothing. At the end of the day I drive the 20 or so miles home in mostly moving traffic. At no point does the temperature gauge raise itself from its usual somnambulant position of around 85 degrees (i should add I never saw it rise above this whilst I went for the lunchtime drive either). No further water loss and nothing since.
From the position of the original water loss I am "mostly" certain it did not come from the radiator overflow pipe.
I will probably take it to have the radiator pressure tested but wonder if people have any theories on what might have happened; frankly I am more perturbed that it has not continued to leak than if it had-at least then its a simple case of finding the source.
