Urgent help needed - wishbone fitment
McQuaid
ML270 cdi '01
Hi guys
So I've just had to remove my lower wishbone on the front right of my ML270, now, fitting it appears to be a different story, is there different positions it can be fitted into on torsion bar? I've my road worthiness test in 4 hours! Under alot of time pressure, any help would be appreciated
If you are thinking of doing a suspension alignement which should be also done with the work you are doing, the time period may be a bit short :eek:, not unless you are a F1 or WRC mechanic :D
You need to measure the ride height by inserting a old drill bit in to the rear of where the torsion bar mounts and then mark the front too. Remove the bar. The ride height is adjustable by the rearmost mounting bolt of the bar.
