Howdy!
So... eventually decided to look into it... jacked the car up and rattled the wheel, there was a bit of play {guessing 2mm-ish in being able to move the wheel horizontally away from the car}. Rotating the wheel had a "rough spot" which scraped on each turn (this was after the caliper was off, so no rubbing with the brake pads possible) (just found the parenthesis key on this keyboard!)
With little more than a leatherman, a rubber mallet and a wrench {oh and an allen key} I got the various bits of the bearing off... turns out 2 of the bearings are not cylindrical {they roll funny
} and the metal bit between them had snapped and truly disintegrated into the bearing... the grease felt like it had sand in it...
Theres a merc dealership near us, but they have a siesta until 5pm - then they open until 7pm... so with some major luck, they'll have the bearings in stock. I'm also going to grab a taxi into town, and see if I can find an identical bearing set from random garages... not much luck, but I feel that if I don't try things will be very screwed up...
Regarding the noise - it had gone away... then come back a bit {but more as a scrape than the repetitive clunking noise...} May have been the speed I was driving at... anyhow.. let's see if I can find a taxi now... fingers crossed! (anyone know a good indy in Tarifa/Algeciras ?
Ian, where are you when I need you?
M.
