Hi guys!
Firstly I wanted to say hello, its the first post on this forum.
I have a common problem with my 2002 CLK320 W208 Coupe.
Problem:
Car runs perfectly, although when it gets warm round 80 C it shakes a little when in drive. The rpms come down just a little and you can feel a rattle.
I notices that when it gets above 80 degrees when its hot than it shakes less.
Secondly, the fault is more noticeable in Drive. When the car is in N revs go up as engine is less stressed and it doesnt vibrate as much.
Thirdly, I noticed that when in Drive "Idle" e.g. when waiting on red light RPMs are low. They are below 500, approximately 400.
What was done:
Spark plugs changed, coils and wires checked, diagnosed (no codes), MAF checked. One guy gave me a forte injector cleaner:
http://www.forteuk.co.uk/ForteAdmin/Product_IMAGE/original_49_specialist_injector_cleaner.png
It is hard to say if it helped. It seems like it did a bit but the problem still exist.
My suspicion is throttle body or throttle body actuator. At least that is the next thing I would like to check.
If anybody has a DIY guide how to get to throttle body and disassemble it from the engine than I would be very grateful as I couldnt find any. I tried two times to take the air intake off but I failed unfortunately.
Anybody has any experience with this problem ??
Can you help guys??
Thanks in advance!!!
Bonus - My car in attachment
Problem:
What was done:
Can you help guys??
