BigFactHunt
- Jan 6, 2015
- e55
Hi, first time poster looking for a little advice if possible.....video included below. ..
I recently bought a W211 e55 and have spent the last couple of months fixing various bits and pieces and getting it to my liking, one strange issue I've been having that I'm struggling to resolve is that the car will randomly without any pattern to it flicker all interior lighting console, dash, doors and overhead...and the nearside(offside front lights both fine)low beam and side light, and both rear lights all flicker , I did suspect the passenger footwear front sam and swapped that out (coded correctly with star) and for a few days I didn't see the issue at all... but it has returned multiple times now....
Additional attributes are :
1: only happens when starting the car and as soon as the ignition is in position 2, has never occurred once car has started normally.
2: when it happens,front lights will come on and flicker regardless of the position of the lighting switch
3: with engine still running , sometimes it stops after a few seconds , sometimes it has gone on for 10 minutes or longer.
4: when this happens ...if i try to check battery voltage when key in position 1 and press trip button three times it doesn't display the battery voltage..weird......
5: as per video the dials of the dash do not light up when it does this but the needles flicker, when it corrects itself the dials light up okay.
6: both batteries are new , MB battery's and voltage when running is at 14.0 - 14.7
I have STAR and it shows no codes of significance to this......that I can see anyhow. ...
Was hoping someone may have seen this behaviour before and could advise
W211 e55 amg lighting / electrical problem: http://youtu.be/BUpSaWZ7gyc
