Viseeo poor sound quality.
Chattonmill
Northumberland
S211 E55 AMG
I have been informed that the quality of the sound on my hands free is not good. It sounds fine in the car, but the person at the end of the phone says it is difficult to hear.
Any Thoughts?
Max
Any Thoughts?
Max
Have you tried adjusting the volume on the side of the viseeo during a call? If you turn the volume control all the way up and gradually turn it down during a call until the optimium level is reached, this should help greatly.
Is this something that was fine before but has just gotten worse? When I first fitted mine I had to adjust the volume as Alfie described.
I thought that according to the MBU-1000 instructions depending on the type of set up you had to have the volume set all the way down. If that isn't the case then I need to experiment as the volume is low.
Or half way, as you say depending on the type of setup you have.
