bretiller01
Hi All, new here and hoping someone can help
Bought a 2.0 petrol vito 113, eventually it'll be my excellent surf van, been battling with loads of problems, asr,fueling, ROT! you name it! etc etc but the latest one has got me stumped
It has a parasitc battery drain through fuse 12 - heater control, average of 1 amp, killing the battery in 1/2days. the system seems to stay awake. With the van off, key out, doors shut - i can still turn the temp control up and down and hear the DUO VALVE working, its an electrical setup not cable and it is not the little electric pump i can hear, its definatly the duo valve. I can't hear any fans spinning, Could this be a stuck relay? providing a constant feed?
if i pull the fuse the drain drops significantly- but then the side lights dont flash when i lock it? fuse back in and lights flash.
I checked the codes and got nothing back, i even created a few and pulled 1 or 2 sensors to make sure my reader was working.
Van seems low on power aswell
Any ideas?
Any ideas?
