w107 n/s electric window
E55AMGV8
barnsley, south yorkshire
W210 E55 AMG
hi all,
i have a w107 350sl and my passengers window has stopped working. i have checked the fuses in the kick panel and they are all ok.
is there another fuse box hiding somewhere or am i missing something??
please help me
ps.. the window is stuck down at the minute
cheers
jamie
Unlikely (bit not impossible) to be a fuse.
Put on the interior light. Does it dim when you operate the switch? If it does, it is most likely jammed or faulty motor.
If it doesn't, it can still be the motor, but you need to start testing.
Pretty sure that you can pull the multiplugs off the switched on those, so you could try plugging into the switch on the side that works.
First thing...
Have you tried taking out the relevant fuse and cleaning the fusecaps and the spring holders? These things are notorious for looking to be OK but are corroded in place. Even giving it a twist in the holder sometimes makes it work. Next step is the switch.
