grahamf505
- Mar 24, 2004
This is unbelievable....
After having problems last week with my fuel supply and having fixed it the weekend and drove 250 miles with no problems, the same thing has happened again.
A quick re-cap.....
Last week my fuel pump relay was tripping out and (I assumed) was causing the fuel pump to go on intermittent operation. The result was the car would die on me, pick up, sometimes cut out and after a few attempts to re-start, I could hear the pump energise and then she would run for a while and then start tripping out again.
I changed the fuel filter and put a new relay on the weekend and drove 250 miles up and down the motorway and around the suburbs in London - so good mix of driving. Absolutely no problems at all.
Imagine my disappointment and frustration then, when I try to use it for the first time since Sunday and half a mile down the road, all the symptoms I had last week re-appeared.
So now what.....??
I'd assumed that my problem was the relay, but surely after only about 6 or 7 hours operation it wouldn't fail again - unless of course there was something else causing it to fail.
What about the fuel pump? It was fine once I'd changed the relay last weekend and was energising and then running whilst the engine was running. Could it be my fuel pump failing intermittently?
The strange thing was last weekend, as soon as I put the new relay in, it was running fine. Maybe just moving the pump around dislodged something and I solved another problem last weekend when I actually thought it was my realy giving problems. However, I did try replacing the new relay with the old one last weekend once I'd done the filter etc, to check if the old relay was giving problems and as soon as I put the old one in, the fuel pump started dropping out again.
Are there any other components I need to check that might be causing this problem? Any help/advice greatly appreciated as an unreliable Mercedes is a very frustrating animal!
Graham
A quick re-cap.....
So now what.....??
Graham
