firstly hello everyone i am new
i have just brought a very clean 1985 w123 230e auto and allthough i love it i have a problem with idleing
it also has been lpg converted which is working fine it will even start on lpg !
the problem is there weather its running on petrol or gas
it will start hot or cold and tick over about 900rpm but very lumpy i have replaced plugs leads to rule out missing as thats what i first thought
it runs lumpy when its cold or hot it makes no difference and the engine shakes
when driving it when first putting it in drive or coming to a stop the revs are really low and it feels like it wants to stall
when driving off from 1000rpm to say 2000rpm ots lumpy and you can feel theres a problem but over 2000rpm it seems to go and the car flys
In neutral when you rev it you can hear this also above 2000rpm it seems to be fine
want to know what i should be checking and whats a good order to check
i wanted to try adjusting the petrol mixture but the screw hole where u pull out gromit on air filter was really rusty
but wondered maybe its not mixture cos it does it running on gas
thanks for taking the time to read
