W124 300CE headlight wiper intermittent fault
Mike Wilkins
300CE
My left hand headlight wiper stays on sometimes when lights are on after windscreen washer has been used. Right hand one behaves correctly. Also this causes them to park out of synch. Any ideas ????
Mike
One wiper motor has switch contacts that feed the other motor. So logically the one with the switch (offside?) is at fault
Nick Froome
Thanks Nick
-- so I guess it should be apparent from the wiring which one has the switch ?
--- so as a first hit I should clean all connections
Should they operate all the time the windscreen wiper is on, or should they just do one sweep when the washer is operated ??
Cheers
Mike
