grober
MB Master
Its also a question that occured to me. There are a lot of differences of course. The lower suspension arm is a cast unit with a large bushed mounting point/pin for that yoke. - bit like a shock absorber. You could possibly get round that by welding on a mount on to the existing W124 arm or fabricating a new arm. Its the upper part thats problematical- the upper shocker part of the w210 strut appears to locate the spring in the vertical by passing through the spring perch and terminating further up in a further top mount higher up. This would not be possible in the W124 since the existing strut is mounted up there in that region. Any substitute fabricated W124 assembly would have to terminate at the existing spring perch in some way I think as its function would merely be spring location. This is all speculation of course as the geometry of the whole set up and the relative strut/spring/ spring perch geometry /angles might be completely different??
2001 E320 4matic front drive axle replacement - Page 2 - Mercedes-Benz Forum
