I had a look behind my dashboard and saw the bulb tell you there is a light problem was blown. I replaced it and it comes on every time i switch the lights on (main light or side light setting) after a couple of seconds.
After searching here i found that it is normally rear number plate bulbs which should be 10W so i replaced there and it still comes on.
Then I saw the next most commmon reason is corrosion on rear cluster contacts. I removed both and both looked good but gave it all a clean and it still came on.
Next i realised i had a dash illumination bulb out in the clocks so i replaced this.....suprise suprise it is STILL coming on!! what is the problem? Every single light works in the car from the glovebox light to the brake lights. The only thing i think it could be is that the car has a towbar fitted with electrical connections which must tap into the lighting circuit if connected (never tried to connect anything to the tow bar). Would this cause this fault to come up? Any other ideas??
