W124 Electric Window
aviationartist
My driver's door window has stopped working although I can hear the motor running. Is this a manageable fix? Hoping it might be simple of course!
on my w124 the teeth on the regulator had worn out, someone had previously welded blobs of weld and then filed them toothed like so the reg worked again.
Maybe the teeth on yours have worn away :/
You will most likely need a new regulator as they can strip their teeth....very common.
Pretty straight forward to replace the regulator
