DriftworksJames
I'm going to change the front shocks on my W124 260E as the existing ones are very tired. Not certain if I need to do the rears, so I'll replace the fronts and see how I get on.
I'm fairly handy with a spanner or 2 but just wnated to know if there are any pitfalls I should be wary of.
From an initial glance, it would seem the job is essentially:
jack up
take wheel off
undo bolts at top and bottom of old shock
retract damper and take off car
fit new one and extend to reach the top mount
do bolts back up
put wheel on
drop car back on floor
am I kidding myself or it it actually that easy? I'm used to needing spring compressors for this kind of job, but it seems I can do this job without touching the springs.......
thanks in advance,
James
jack up
take wheel off
do bolts back up
put wheel on
thanks in advance,
James
