My 1994 e320 has started intermittently cutting out due to interrupted electrical supply to the fuel pump. I have checked the Fuel Pump and replaced the Fuel Pump Relay with a brand new one, but to no avail. The fuel pump will run perfectly, then suddenly loses its power supply and the engine obviously won't start again until, for no apparent reason, the power supply is restored and everything is back to normal for a short time. What else can I check? E.g. is there a fuse anywhere (additional to the fuse on the top of the relay) that might need its contacts cleaned?
