punjabi
300TE - After driving around for about half an hour this morning, I stopped at the local shops and saw a trace of fine 'smoke' appear from the underside of the car at mid-section below the doors......bent down and discovered that it was from the traces of leaking oil which had blown onto the exhaust pipe. The oil appears to be dripping from the auto gearbox (towards rear side of pan). Any ideas where the actual leak could be......pan gasket or some other place? Car is otherwise driving fine........
